Activity Forums Blackmagic Design BM in FCP 4.5
  • BM in FCP 4.5
    Posted by Tomislav Rukavina on December 15, 2007 at 6:29 pm
    HI,
    having solved se QT 7.3 problem by installing new OS 10.4 over 10.4.11 i had to install a new BM driver so I downloaded one from the BM site. I didnt work so i removed it and installed the one that came with the box. I works just fine now but i lost some sequence presets in FCP. I used to have BM 10 bit (YUV), BM 10 bit, BM 8 bit and BM 8 bit (YUV). Now I have BM 10 bit (DV10) RGB etc.
    Not that it’s a big problen cause everything works just fine with apple uncompressed codec I just don’t like wierd messages popping up. I can’t export and import footage in plain old BM 10 or 8 bit. Both from FCP and AE. Library/QuickTime seems OK.
    G5 2.0 dual / 2.5 GB RAM / DeckLink Extreme /FCP 4.5.1/ OS 10.4 QT 7.0
    thanks a lot in advance
    Tom
    Tomislav Rukavina replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
