Activity Forums Apple Final Cut Pro Legacy BM HD Extreme & HDV – Monitoring Issues
  • BM HD Extreme & HDV – Monitoring Issues
    Posted by Tim Gibbons on October 12, 2008 at 6:27 pm
    Hello Guys,
    I’m hoping someone out there can help me figure this out. I just imported some footage using a Canon XH A1 via firewire. Settings are as follows:
    Shot in 1080 24f
    Captured using Easy Setup HDV 1080p 24 Firewire Basic
    Monitoring on a TVLogic monitor via SDI
    The footage looks fine in FCP’s viewer but it looks squeezed (length) in the HD Monitor. When selecting a Video Playback selection, all of the “HDV” options are grayed out.
    My guess is that it has something to do with HDV coming in at 1440 instead of 1920 and the capture card not being able to convert and output that signal correctly. I can’t get it to size properly no matter which Video Playback selection I choose in FCP. BM doesn’t have an easy set-up for HDV as far as I can tell.
    Any ideas?
    Thanks for the help!
    Tim Gibbons
    Tim Gibbons replied 17 years, 11 months ago 2 Members · 2 Replies
  • David Roth weiss
    October 12, 2008 at 7:21 pm
    Tim,
    Almost all (but not in every case) HD displays to HD monitors as 1080i 8-bit 29.97. Choose that setting in View >> Video Playback and you should be good to go.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Tim Gibbons
    October 12, 2008 at 10:19 pm
    David!
    That did the trick. Thank you so much. I don’t think I would have tried the 1080i options for 24p(f) footage.
    Thanks again.
    Tim
