Activity Forums Blackmagic Design BM 8-bit capture – the Final Cut Pro sequence settings?
  • BM 8-bit capture – the Final Cut Pro sequence settings?
    Posted by Keith Mann on June 22, 2007 at 3:30 pm
    I’m doing my first final cut pro edit with blackmagic 8-bit 4:2:2 uncompressed.
    What is the blackmagic frame size aspect ratio and pixel aspect ratio’s?
    Is any of this aspect raio stuff going to comeback and bite me when I compress of DVD?
    Thanks in advance
    Simon Blackledge replied 19 years, 3 months ago 2 Members · 1 Reply
  • Simon Blackledge
    June 22, 2007 at 9:35 pm
    PAL? NTSC ?
    One thing I’ve come across doing PAL edit > DVD. Send a PAL (720×576) 5:4 anamorphic edit to DVD StudioPro, DVDSP makes the image 720×405.. tell it 4:3 and slightly better at 720×540.. still c’mon.. it’s 720×576.. very wierd.
    Anyway.. QT, fcp Export and Compressor all seem to do really bad scaling so I always rescale the final timeline in Shake, but I only do shortform.
    Post how you get on, but yes.. it will… so do some short tests first! 😉
    S
