Activity Forums Adobe After Effects Blurry Video Render from After Effects
  • Blurry Video Render from After Effects
    Posted by Jonathan Lewis on November 3, 2010 at 12:19 am
    I am working with footage that is 960×540 originally filmed on RED. I am trying to resize the footage (which is keyed) to fit a comp of 500×250. The footage, when rendered out in its original size and comp is totally crisp and fine. I’m finding that when I resize it, the final render is blurry and a bit ‘soft’. I originally thought it was because i was nesting comps and resizing them. I re-did everything and the only thing i am actually resizing is the footage layer. Everything is crisp in preview but again, comes out soft. I am creating a quicktime with compression set to ‘NONE’. Also, if it means anything I am rendering out RGB+Alpha (millions of colors+). What is going on!!!! HELP
    Jonathan Lewis replied 15 years, 10 months ago 36,115 Members · 1 Reply
  • Jonathan Lewis
    November 3, 2010 at 12:29 am
    Yeah I’ve never worked with it either. However, doing a regular render (without resizing) produces a perfect, crisp, render. I just don’t understand what could be causing this softness.
