Activity Forums Adobe Premiere Pro Blurry Slow-Mo
  • Blurry Slow-Mo
    Posted by Chris Dolan on November 9, 2005 at 6:58 pm
    One of the things I’ve struggled with this year is how to make my slow-motion footage less blurry. Unaware of any other methods, I simply slow the speed of the clip to whatever percentage I need. The problem is that it appears considerably more blurry than the rest of my footage. I understand that PPro interpolates between frames to keep it smooth, but even adding a sharpen filter does nothing to make it look clearer. I also tried turning on ‘Always Deinterlace’ in the field options. PPro ‘Help’ recommended this for slow-mo clips. It didn’t appear to help and actually made the image flicker a little. Is PPro the place to do slow-mo or should it be done in AE? Sadly, I haven’t learned AE yet so I’m hoping that there’s a better way in PPro.
    Derrick replied 20 years, 10 months ago 4 Members · 4 Replies
  • Tim Kurkoski
    November 9, 2005 at 9:08 pm
    Premiere Pro does not have the best time remapping engine. After Effects is better, but for best results you’ll probably want to investigate a third party plug-in. I forget the names, and I seem to recall debates over which is better, so you’d best ask on the After Effects forum.
  • Derrick
    November 10, 2005 at 12:36 pm
    Twixtor is a brilliant plug in for this purpose!!!
    – Derrick
  • Bill Mccallum
    November 11, 2005 at 4:07 am
    Where can I find twixter?
  • Derrick
    November 11, 2005 at 4:46 am
    Hi there,
    Here is the link:
    https://www.revisionfx.com/rstwixtor.htm
    – Derrick
