Activity Forums Maxon Cinema 4D Blurry reflection 20%+ looks terrible
  • Blurry reflection 20%+ looks terrible
    Posted by Kevin Camin on August 20, 2012 at 6:04 am
    I’m using R13 and have been trying to create a blurry reflection by adjusting the parameters in the Reflection channel of the material. When I pump up the blur amount, the resulting blur is very spackled looking, like spray paint. I’ve tried upping the Samples under the parameter but it appears to have no effect.
    Any help would be appreciated.
    Best regards,
    Kevin Camin
    Brian Jones replied 14 years ago 2 Members · 3 Replies
  • Brian Jones
    August 20, 2012 at 4:44 pm
    probably you need to increase the minimum samples a lot
  • Kevin Camin
    August 20, 2012 at 5:58 pm
    No, I increased the samples to the max and it still looks like splattered paint.
    Best regards,
    Kevin Camin
  • Brian Jones
    August 20, 2012 at 7:24 pm
    what are your setting for Minimum Samples/Maximum Samples and Accuracy?
