Activity Forums Adobe Premiere Pro Blurry in pp when I zoom in HDV Footage
  • Blurry in pp when I zoom in HDV Footage
    Posted by Martin Vincent on July 12, 2008 at 1:58 pm
    I capture HD and output to SD, I use the over-res to zoom digitaly in my footage to make valor changes “changement de valeur” (sorry I dont know how its called in english), I zoom on faces or else. But it seems to be blurry a little is there a solution to that?
    Steven L. gotz replied 18 years, 1 month ago 3 Members · 3 Replies
  • Vince Becquiot
    July 12, 2008 at 4:38 pm
    You would have to bring in the original HD footage to be able to zoom in (or out in that case) without resolution loss.
    Vince
  • Martin Vincent
    July 12, 2008 at 4:49 pm
    Thank you Vince
  • Steven L. gotz
    July 15, 2008 at 4:58 pm
    You can not zoom in while editing in a HD project and not have a loss of quality.
    If you import the HD into a SD project you can, but only if you do not automatically scale it to the project’s frame size first. And do not exceed 100% of scale. (I assume that the value you are changing is the “Scale” parameter.)
    Steven
    https://www.stevengotz.com
