Activity › Forums › Avid Media Composer › Blurry DVCpro HD p2 footage on Media Composer
  • Blurry DVCpro HD p2 footage on Media Composer
    Posted by Tova Goodman on September 15, 2009 at 4:33 pm
    Does anyone know why, in an NTSC 23.98 MC project, my 720p DVCPro HD 23.98 p2 ftg is VERY blurry? It looks fine, however, if I switch the project setting to 720p/23.98. I have a Mojo (not SDI or DX). In the other room here, where there is a Mojo DX, it looks crisp. Help!
    Jim Morrissette replied 16 years, 11 months ago 2 Members · 1 Reply
  • Jim Morrissette
    October 14, 2009 at 5:37 pm
    Hi Tova,
    This is an easy fix if you are using AVID 3.5 or later. You need to disable the AVID AMA to allow analog Mojo to down-convert a nice clean standard definition monitor signal while editing.
    Go to project settings-AMA-Volume mounting tab and deselect “enable avid AMA”. restart avid and your
    P2 720p files will play with clean (non-blurry) standard def resolution. You may have to cycle through the green/yellow video quality button in the lower right side of the timeline window to full green.
    Jim
    Jim Morrissette
    Technical Director
    Kartemquin Films
    jim@kartemquin.com
