Activity Forums Adobe After Effects Blurring Camera Animation
  • Blurring Camera Animation
    Posted by Jason Brown on June 22, 2016 at 6:14 pm
    Newbie question.
    Okay set up: camera parented to null, cam focus distance pickwhip’d to cam position.
    I was under the impression that with this set up everything would stay in focus, however when I zoom in (with null z-position) my asset goes out of focus.
    Now am I correct in thinking that I just have to keyframe the blur in the camera properties from 100 to 0?
    Just wondering if there’s another way so I don’t have to keep keyframing the blur.
    – Jason
    Jason Brown replied 10 years, 3 months ago 2 Members · 2 Replies
  • Juliette Backey
    June 22, 2016 at 6:40 pm
    Depending on the effect you are going for you can actually link the Focus Distance to a specific asset. So if you never want that object to go out of focus you would select the layer and the camera, right-click on the camera layer, select Camera… from the flyout menu, then select Link Focus Distance to Layer.
  • Jason Brown
    June 23, 2016 at 2:32 pm
    Thanks for the reply. I’m using a single-node camera and this option isn’t available unfortunately. I’ve gone with keyframing the blur, looks better than I thought.
