blurring
Posted by Doyal Gudgel on August 13, 2011 at 7:35 pm“Use the Size, Center X, and Center Y controls to position the mask over the part of the video you want to blur.” this is a picture of my screen but I am stuck Where is the mask? The dup track does not sync with the video dupe track. What next?
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.comDoyal Gudgel replied 15 years ago 2 Members · 9 Replies -
Mike Kujbida
August 13, 2011 at 8:14 pmChoose something (anything) in the Cookie Cutter preset and go from there.
Doyal Gudgel
August 13, 2011 at 9:17 pmI got the cookie cutter stuck in the top corner but cant get it down but I think it will work to get rid of all editing memory. I looked for it but didn’t find it. Where is it?
Hope to see you
https://seniorobserver.blogspot.com, https://billswar2.blogspot.com -
Mike Kujbida
August 13, 2011 at 9:20 pmJust below the X in the top left of the Cookie Cutter window is a series of vertical dots.
Click on those and drag the window back out to undock it. -
Doyal Gudgel
August 13, 2011 at 9:51 pmOK thanks. What am I supposed to see? Do?
Hope to see you
Doyal Gudgel
August 14, 2011 at 2:30 amOK what do I do now. I’ve done everything but put a spot where it is supposed to be. I see the object in the window in lower left but I don’t know what to do with. I think I am near my solution but I need just a little more help. This is near the anniversary of Woodstock and I have a film if I can get it blurred out.
Have a nice day -
Mike Kujbida
August 14, 2011 at 12:06 pmChoose the type of cut out you want (circle, square, rectangle, etc.) in the Cookie Cutter preset.
Size it using the Size control slider.
Position it either by entering numbers in the Center X and/or Center Y boxes OR grab the small box in the center of the white space to the left of these settings and drag it around. -
Doyal Gudgel
August 14, 2011 at 5:38 pm
We are getting there but I still need help. How do I move the blur that is there in the bottom video to the spot on the woman that needs blurring? There seems to be a blur on the shirtless guy to the right of the subject I want to put it on. Actually two blurs looks like. Of course it is going to have to move with the subject but first things first. I have to manipulate the blur plus placing it where I want it, size and so on. This video doesn’t sync with the video display window so I will have to find out what to do with that soon.
Any help is appreciated. I wish Sony would not say something is easy.
Doyal HAND (Have a nice day) -
Mike Kujbida
August 14, 2011 at 6:17 pm -
Doyal Gudgel
August 15, 2011 at 6:35 pmThanks. I will give it a try.
Hope to see you
