Activity › Forums › Apple Motion › Blurred video when doing export
Posted by Ulriks on August 3, 2005 at 1:55 pmMy problem is this. Ihave created a smal intro and everything look crisp and nice in Motion but when I export is (as DV – pal) everything gets blurred. What am I dooing wrong ??
Hope you can help me
Regards
UlrikUlriks replied 20 years, 9 months ago 2 Members · 4 Replies -
Uli Plank
August 3, 2005 at 9:21 pmDV is not a perfect codec, it is reducing color-resolution and it uses compression.
This can be quite obvious if you have graphics with sharp edges and highly saturated colors. You may need to change your design for DV output.
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
Ulriks
August 4, 2005 at 7:29 amHi Uli
I have one graphic from photoshop and two pices of text generated in Motion. The background is black and the graphic and text are white. The graphic has sharpe edges so I will have a look at that one.
Any other ideeas ?Regards
Ulrik
Uli Plank
August 4, 2005 at 9:07 amWhite text on black is a critical combination for DV – try to lower the contrast.
And please have a look at this excellent article:
https://www.kenstone.net/fcp_homepage/perfect_titles_phil.html
(A very helpful site anyway).
Hope this helps,
Uli
Ulriks
August 4, 2005 at 1:58 pmHi Uli
No blur no more 🙂 Thanks for you help, and thanks for the link
Regards
Ulrik
