Activity › Forums › Adobe After Effects › Blurred Output
  • Blurred Output
    Posted by Orme Dominique on April 15, 2008 at 10:10 pm
    When I do a final output, my renders look blurred. I’m almost sure this has to do with the Collapse Transform feature, but I can’t figure it out… please help if you can.
    Thanks.
    Orme Dominique replied 18 years, 5 months ago 2 Members · 2 Replies
  • Darby Edelen
    April 16, 2008 at 12:01 am
    [Orme Dominique] “When I do a final output, my renders look blurred. I’m almost sure this has to do with the Collapse Transform feature, but I can’t figure it out… please help if you can. “
    Can you describe your workflow in any detail? How are you using collapse transformations? What codec are you rendering to?
    Darby Edelen
    Lead Designer
    Left Coast Digital
    Santa Cruz, CA
  • Orme Dominique
    April 16, 2008 at 1:20 am
    Okay, so I’m a little fuzzy on what collapse does, but generally I use it to treat pre-comps as whole discreet element with all their effects and such flattened. In this comp I have multiple nested clips that use video from several sources. Then I output a movie and then import it into another project where I do a final conform and soundtrack. Its so odd. The base files look fine, but then I render through the render queue and it comes out fuzzy. Then if I just go to export and do the same thing, bam… no problems. Its very odd indeed.
