Activity › Forums › Apple Final Cut Pro › blurred clip
  • blurred clip
    Posted by Ismet Arnautalic on June 4, 2016 at 9:03 am
    I shot a take (1920×1080) with DJI OSMO camera and when I watch it through Quick Time Player everything is ok. After importing it to FCPX and putting it to Timeline the take is little blurred. When I stop play mode steel frame is ok. Therefore, in play mode the take is not ok.
    Anybody knows the reason and solution of this problem?
    Nuno
    Ismet Arnautalic replied 10 years, 3 months ago 3 Members · 3 Replies
  • Jeremy Garchow
    June 4, 2016 at 12:42 pm
    This seems to happen with all DJI clips (OSMO, inspire, etc). It’s fine once exported. You could render that clip in the timeline or optimize the media. There is nothing wrong with the media.
  • Jeff Kirkland
    June 5, 2016 at 6:58 am
    You might also just double check you haven’t accidentally got the viewer set to best performance.
    (For some reason I can\’t edit my own posts so apologies in advance for the stupid mistakes and bad English that I can\’t go back and fix)
    Jeff Kirkland | Video Producer & Cinematographer
    Melbourne, Australia | Twitter: @jeffkirkland
  • Ismet Arnautalic
    June 5, 2016 at 8:01 am
    Thank you for advice. That was solution for maj problem. Regards
