Activity › Forums › Apple Final Cut Pro Legacy › Bluring beyond frame size
Posted by David Battistella on September 28, 2005 at 5:30 pmHi there.
I have a file I brought in as photoshop layers.
Problem.
If I want to blur something out, FCP is limiting the blur to the Box size of the layer. Is there a way to trcking it into thinking the layer size is larger. The file was all lined up in photoshop. Should I make it all large and then line it up in FCP or fill thelayers of the photoshop files with a color to trick the frame size.
maybe an alpha thing I can do?
David
Kevin Monahan replied 20 years, 11 months ago 3 Members · 7 Replies -
Kevin Monahan
September 28, 2005 at 5:39 pmPlace Four “dots” in each corner of the raster for the blurred layer. Reduce the Opacity to Zero. This will force the layer to blur to the edges.
Kevin Monahan
Author – Motion Graphics and Effects in Final Cut Pro
fcpworld.com -
David Battistella
September 28, 2005 at 5:45 pmKevin,
I think I am partially getting this. Do I create the dots in Photshop or FCP. I need just a bit more explaination.
David
Walter Biscardi
September 28, 2005 at 7:57 pmJust Nest the layer in FCP. This will turn the layer into the frame size of your comp.
Walter Biscardi, Jr.
Creative Genius, Biscardi Creative Media
https://www.biscardicreative.comNow in Production, “The Rough Cut,” https://www.theroughcutmovie.com
Now editing “Good Eats” in HD for the Food Network
G5 Dual 2.0, AJA Kona 2, Medea FCR2X
Kevin Monahan
September 28, 2005 at 10:04 pmSlipped m’ mind holmes…..
Yup. You can do that as well.Kevin Monahan
fcpworld.com -
David Battistella
September 29, 2005 at 1:05 amSorry Kevin,
I am a bit confused. Are you actually offering help or am I missing something here.
I just asked for a bit of clarity and some more detail on you initial response and this feels like it is turning into a riddle.
Have I done something wrong in asking for more os an answer?
David
David Battistella
September 29, 2005 at 1:16 amKevin,
Sorry.
I have msiread these posts. Walters method works well, but I still dis not fully comprehend the workflow you offered up. 🙂
did not mean to be snippy.
David
Kevin Monahan
September 29, 2005 at 11:04 pm[David Battistella] “did not mean to be snippy.”
No trouble old chum.
The four dots can be made with the paint brush.
Place them in the four corners of the layer.
This extends the border of the layer to the edges of the screen.This method is described in Lisa B.’s Visual QuickStart Pro in the Photoshop section.
Take a look if you have the book.Kevin Monahan
fcpworld.com
