Activity › Forums › Adobe After Effects › Blured Precom in 3D mode
  • Blured Precom in 3D mode
    Posted by Thomas Caryn on February 22, 2023 at 3:40 am
    Hello Folks,
    First of all, I’m new on that forum and in the After Effects’ world.
    I try/like to learn by myself but now I’m stuck.
    I’ve drawn letters created from pattern of lines (vector shapes) on which I apply a mask.
    Every line is animated with the “Trim Paths”.
    Everything is clean until I turn “the little black sun” on (don’t konw how to translate that button, it’s to keep your vector layers sharp when you scall them).
    When I activate that function, all my precomp becom a little bit blured.
    Also when I turn those “little sun” on some of the options become unavailable on those layers : fusion modes, mouvement blur, keep the transparancy… this could be a clue?
    There are no camera in the main composition, so no depth of field.
    I’ve also tested with a “sharp effect” on a top layer but some precomp seems to be more blurry than others.
    Enclosed you’ll find some screenshots.
    Hope my english is not so bad cause it’s not so easy to explain such a problem…
    Thanks a lot.
    t.
    Thomas Caryn replied 3 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
