Activity › Forums › Adobe Encore DVD › Bluray Motion Menu Bitrate
  • Bluray Motion Menu Bitrate
    Posted by Cody Walters on August 14, 2012 at 3:16 pm
    I created a motion menu for a Bluray dic in After Effects and exported to MPEG-2 Bluray. I believe the data rate was set to 30Mbps using the preset. I used the same preset for my 8 minute video.
    After burning, the 8 minute video looks great playing around 25 to 30 Mbps, but the Menu video is playing at most 8Mbps. Why would this be? I checked to make sure Encore was not retranscoding on output and it is not (set to Don’t Transcode). Does Encore adjust the Mbps if it is for menu or is this a limitation for a Bluray Menu?
    Thanks for the help,
    Cody Walters
    JW Studio LLC
    Houston Video Production
    Houston Wedding Videographer
    Final Cut Studio 3
    Adobe CS5 Master Suite
    Panasonic HVX-200
    Canon 7D
    Daniel Ludwig replied 14 years, 1 month ago 2 Members · 1 Reply
  • Daniel Ludwig
    August 21, 2012 at 1:47 pm
    hi cody,
    you´ll hav high bitrates when your picture will have a lot motion and movements, and lower bitrates when there is less motion and movement.
    if you set your encoding VBR the encoder could use these values (peak limit/everage) but it should not use it, if not necessary.
    cheers
    danny
