Activity Forums Apple Final Cut Pro Legacy BluRay burning headaches (FCE -> )
  • BluRay burning headaches (FCE -> )
    Posted by Rick Peters on September 16, 2010 at 12:52 am
    Not sure where to post this … but I’m working on some HD concert footage in FCE HD 3.5.1, using Compressor 3.0.5 … (I don’t own FCP and have no upgrade path to Compressor 3.5).
    I got good results using some tips from these forums getting my concert SD DVDs through Compressor, with satisfactory results. Now I’ve output the sequences as self-contained Quicktime movies in HD with chapter markers, and can’t figure out how to get these files to burn correctly using Toast 10.0.8 and a BluRay burner.
    I’m losing my chapter markers no matter what, and within Toast, even pulling in a clip of each individual song to force individual tracks, I’m getting a 1-second pause between tracks, which is not good because the music is flowing from song to song. The footage looks and sounds fine with Toast doing the encoding, but I can’t live with the pauses between tracks and there’s no way to skip from track to track without going back to the main menu because the forward and back buttons don’t work.
    Is there a way to get chapters out of FCE 3.5.1, either via Compressor 3.0.5, or not, into Toast 10.0.8 and have it create a menu with chapters that actually work? Any help would be greatly appreciated.
    Dennis Radeke replied 16 years ago 4 Members · 5 Replies
  • Rafael Amador
    September 16, 2010 at 4:44 am
    And why don’t you use a proper application, like DVDSTP, to do the job?
    rafael
    http://www.nagavideo.com
  • Rick Peters
    September 16, 2010 at 4:53 am
    I did use DVD studio pro to burn the SD DVDs, but it doesn’t do BluRay, only HD DVD. Or, at least the version I have doesn’t.
  • Michael Sacci
    September 16, 2010 at 5:04 am
    DVDSP DOES NOT do BluRay. But the newest version of Compressor does.
  • Rafael Amador
    September 16, 2010 at 5:37 am
    Sorry I’ve got lost.
    Don’t make the transcoding in Toast.
    Use Compressor and bring the MPEG-2 (H264 ?) files to Toast. Tell Toast NOT to re-encode.
    The pause between clips (at least in DVDs) is unavoidable if each clip goes in a different track.
    About how to deal with chapter markers in Toast, no idea.
    rafael
  • Dennis Radeke
    September 16, 2010 at 7:46 pm
    Stating the obvious, but Adobe Encore also supports Blu-ray. You could try the Premiere Pro trial (which should include Encore) and see if it addresses your issues.
