Activity › Forums › Adobe After Effects › Blur an object without it disappearing
  • Blur an object without it disappearing
    Posted by Bill Clotz on September 11, 2005 at 8:59 pm
    When you apply a blur to an object, the stronger the blur becomes, the object will appear to start fading away. If you set the blur strong enough, the object will all but totally disappear. You can alleviate the problem by duplicating the blurred layer many times.
    I was wondering if there was any good way of blurring something by a large amount while retaining the luminance of the object without having to deal with duplicating the layer many times?
    Mstleger replied 21 years ago 2 Members · 1 Reply
  • Mstleger
    September 12, 2005 at 5:01 am
    try just using two copies, one that is less blurred, the other overlayed on top. Also, consider using a different blur plug in, perhaps a Tinderbox lens blur, which has a nice bloom option.
