blue ray burn
Posted by Ed Vandenderen on February 7, 2010 at 2:26 amI am ready to burn a 3.25 hour project to a dual layer blue ray disc.
Do I render the sound separately?
Is a file created from which I can burn multiple copies?
Any setting do’s and dont’s you might recommend? Would hate to loose this one, many hours to build.
thank for the help
John Rofrano replied 16 years, 7 months ago 3 Members · 9 Replies -
John Rofrano
February 7, 2010 at 4:06 amYes, you should render the sound separately as Dolby Digital AC3. DVD Architect will make an ISO image of the Blu-ray disc which can be burned multiple times.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Ed Vandenderen
February 7, 2010 at 6:48 pmJohn
If I am burning directly to dual layer bd disc from timeline do I need to do anything regarding architect?
how about settings?
I think you mentioned to me once that you use a media player. May be the way to go.
How would I manipulate the file render to be able to transfer to an external hard drive to then use with a media player -
John Rofrano
February 7, 2010 at 9:14 pmIf you are burning a Blu-ray disc from the timeline you don’t need DVD Architect. Vegas Pro will make a Blu-ray disc image without menus. It’s does produce an .iso image that can be burned multiple times by almost any burning program. If you want to use the footage with a media player then you would render to a file format like AVCHD and not a disc image.
~jr
Ed Vandenderen
February 7, 2010 at 9:32 pmJohn
sorry for the ??? but don’t want all this work to fall into a black hole with wrong settings.I want to burn 3.25 hours of edited hd video taken with the hdr-hc9 from movie studio 9 time line to a dual layer blue ray disc.
Just to make sure would I use the mpeg2, blue 1440×1080-60i template to render?
How do I render audio to ac3 in the process?Do you see any issue with dual layer disc here?
thanks
John Rofrano
February 8, 2010 at 2:48 amI don’t have Movie Studio but in Vegas Pro it gives you the ability to select both the video and audio templates to use. I would use the HDV 1440×1080-60i with the HC9. I have never used dual layer Blu-ray but it should hold up to 4 hrs of 25Mbps HDV video so you should be fine with 3.25hrs.
~jr
Sebastien Gravel
February 10, 2010 at 3:29 amI apologize if this is a hijacking of you thread! I was wondering as well about settings for blu-ray burn. My project was done in 1280X720P, but there is no such option in the blu-ray presets… What should I do?
John Rofrano
February 10, 2010 at 12:17 pmI apologize if this is a hijacking of you thread! I was wondering as well about settings for blu-ray burn
Actually it is for your benefit that you create a new thread with an appropriate title so that more people see it.
I only work in 1080i so I have no experience making 720p Blu-ray discs. DVD Architect has 720p project settings so I assume it can make 720p discs. You could try using one of the existing Blu-ray templates in Vegas Pro and change the resolution to 1280×720 progressive and see if that works.
~jr
Ed Vandenderen
February 13, 2010 at 8:03 pmJohn
I am a little confused, will movie studio timeline burn also leave a .iso file or TS or something that I can then use to burn with say Nero
if I need multiple copies or does vegas ask me if I want to burn another copy? -
John Rofrano
February 13, 2010 at 10:01 pmI don’t use Movie Studio (I use Vegas Pro) but I believe that it leaves the .iso file so that you can come back and burn it as many times as you’d like with whatever program you’d like.
~jr
