Activity › Forums › Apple Final Cut Pro Legacy › Blu-ray won’t play after burning out of Final Cut Pro
  • Blu-ray won’t play after burning out of Final Cut Pro
    Posted by Scott Herriott on January 31, 2012 at 6:21 pm
    Hey there…i’m running FCP 7.0.3. I’m using a OWC Mercury Pro Blu-Ray burner.
    Being doing 1-minute test burns so far and it appears the data is burned on the disk, but when I hit play on the Samsung Blu-Ray player I have I’m getting a “Not Available” message. When I hit play on the machine directly, same thing. The simple menu looks great. I definately need a menu for this film…don’t want it to immediately start playing. I haven’t tried the option of adding the chapter markers yet…would that matter?
    Any help appreciated.
    Thanks in advance,
    Scott
    Scott Herriott replied 14 years, 8 months ago 4 Members · 6 Replies
  • Mark Suszko
    January 31, 2012 at 7:47 pm
    Following your story with interest: I just hooked up my OWC Mercury and burned a test disk Friday, marking in and out on the timeline and using the “share” to bluray function. Our engineer took it home to his PS-2 and it played fine. The share function must take care of finalizing the disk for you, because I didn’t see any dialog about that. Is your BD disk finalized? How exactly did you burn it?
  • Scott Herriott
    January 31, 2012 at 8:21 pm
    I marked In and Out Points, then…
    File >
    Share >
    Set it to “Blu-Ray” >
    Set Output Device to the external burner >
    Picked a disc template (black) > Set “When Disc Loads” choice to “Show Menu” > left Chapter Markers unchecked > left “Loop” unchecked > I added a Background photo > I then hit “Export”.
    It took about 9 min. for the whole process to occur. The disc then automatically ejected out of the OWC Mercury Pro. I popped it in the Blu-Ray player and the menu looked sweet. But when hitting play on the machine and the remote I got a “Not Available” message.
    Again, it looks as though the data is burned on there because I compared it to a blank and I could see a difference.
    fwiw…I double-checked and, indeed, this burner doesn’t need any additional software for it to work.
  • Mark Suszko
    January 31, 2012 at 8:24 pm
    My first attempt was almost exactly as you descrbed, but it hung for over an hour, because I hadn’t specificed where the render files were to go on my video drive first. On the second try, worked fine, took about 2x realtime of the timeline selection. I don’t know that that’s your problem, just saying what worked for me.
  • Bret Williams
    January 31, 2012 at 9:13 pm
    You hit play or enter? DVDs I create in DVDSP work when I hit play on some of my DVD players, but on others I get the international no symbol or not available (sony blu ray player). Hitting play for DVDs isn’t necessarily a replacement for the select/enter button, but usually works. You just can’t count on it. I know some people make the menu item say “press play” but that doesn’t always work unless it’s specifically coded that way. Blu-Ray could be the same issue.
  • Jim Wiseman
    February 1, 2012 at 1:36 am
    This is true. You must hit “Enter” not “Play” for a Sony Blu-Ray player, at least. That one fooled me a while as well. Same appears to be true for a Toast 10 burn as well.
    Jim Wiseman
    Sony PMW-EX1,Pana AJ-D810 DVCPro, DVX-100, Nikon D7000, Final Cut Studio 2 and 3, Media 100 Suite 2.1, Premiere Pro 5.0 and 5.5, AJA ioHD, AJA Kona LHi, Avid MC, Hexacore MacPro 3.33 Ghz 24Gb RAM GTX-285 120GB SSD, Macbook Pro 17″ 2011 2.2 Ghz Quadcore i7 8Gb SSD, G5 Quadcore PCIe
  • Scott Herriott
    February 1, 2012 at 2:38 am
    Wow, that is goofy….and correct!!!
    Many thanks to all who helped out,
    Scott
