Activity › Forums › VEGAS Pro › Blu Ray rendering / DVDA / Reenconding
  • Blu Ray rendering / DVDA / Reenconding
    Posted by Stewart Bourke on April 21, 2014 at 4:35 pm
    VP12 latest version, DVDA5.2 Pro
    Working through first Blu Ray render from VP12. DVDA seems to want to reencode, which I believe ti should not.
    Media shot in Canon HGF30. Have rendered .avc file in VP12 pro, 1920 x 10180, 25FPS (Pal land…), interlaced, top-field first. I used the Sony AVC BlueRay templates, and customised it to set the frame-rate to 25FPS and the bit-rate to the suggested 21,999,616 value. Separate AC3 for audio.
    In DVDA, selected Blu ray disc, set Disc Properties to BLU-ray, AVC, bit rate 22MBPS, frame-rate 25 Interlaced. Everything else as per defaults.
    When DVDA starts preparing the ISO, it seems to want to re-encode. It took nearly 12 hours to create the ISO, which plays fine, but I am trying to find out why it wants to re-encode.
    I have read a load of different posts, and the word seems to be that once you render in VP to the ‘correct’ format, DVDA will not re-render. Clearly I am doing something incorrectly.
    Any suggestions on how to stop DVDA re-encoding?
    Many thanks,
    Stewart Bourke
    Stewart Bourke replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
