Activity Forums Adobe Encore DVD Blu-Ray Image increases in size
  • Blu-Ray Image increases in size
    Posted by Julian Gil on April 2, 2010 at 8:41 pm
    I’m making a Blu-Ray Disc in Encore CS4 and currently, the Disc Info tells me that it is 1.45Gb under the max for a 25Gb Blu-Ray.
    However when I output a Blu-Ray image or Disc my output size increases to 25.58 GB so that I can’t place it on a 25Gb Blu-Ray.
    The funny thing is that just yesterday I created an image from the same project that was under the 25GB limit. However, when I came back to the project to correct a couple of button navigation issues and created another image and that’s when I noticed the size increase. I did not add anything to the project yet the size increase.
    So, I created a new project, and this time it stayed under the 25GB limit.
    I was wondering if anyone else had the same problem? What could be causing this?
    Cael Kuhlman replied 15 years, 10 months ago 2 Members · 1 Reply
  • Cael Kuhlman
    July 6, 2010 at 3:50 pm
    I don’t have a solution yet but I am having the same (or similar problem) – I have two assets – #1 is 9 gigs, and #2 is 13 gigs. The audio is 192kbps Ac3 so it’s not even a factor. Encore tells me that the encoded size will be 26 gigs? How the hell does that add up. Then…here’s the kicker…I make the disc image – it’s 34 gigs… One thing I noticed is that when I go to build the disc image, it instantly acts like it already has written the first 14 gigs and it’s continuing to write the rest.
