Activity › Forums › Adobe Encore DVD › Blu-ray fatal error
Blu-ray fatal error
Ana carolina Trevisan camilo replied 12 years, 4 months ago 17 Members · 25 Replies
Jonas Bendsen
September 19, 2010 at 6:37 pmYeah, I tried the msxml6 patch, but to no avail.
I am definitely writing to .iso as of a couple of weeks ago, as I learned the expensive “coaster lesson” the hard way. BR media is outrageous! [smile]
I’ve been looking for a solution to this problem for nearly a month, but haven’t found a fix yet.
Thanks for your suggestions!
This is my life, I edit and edit and edit and edit… -
Bill Wood
September 19, 2010 at 7:00 pmCan you write a blu ray iso file without the error? If so you can use a program such as Cyberlink’s Power2Go to burn the iso image. – Bill
Jonas Bendsen
September 19, 2010 at 7:03 pmNo. That’s what I was saying. I stopped trying to burn to discs (crazy expensive) a while ago and am just trying to create an .iso now so I can burn the .iso to a disc later.
Thanks for your suggestions, Bill!
Matt Taylor
October 21, 2011 at 2:58 pmWith the naming issue…
I was having the same problem, and then I re-typed my disc name as ALL CAPS and underscores between spaces. That worked for me.
Matt Taylor
May 7, 2014 at 8:43 pmDear friends,
After reading all of your suggestions and applied many of them I could finally get rid off code 6 error (thanks for that) and I was able to create an .ISO file. But now, I’m struggling again to burn a bluray disc. I’ve tried using Nero and ImgBurn, but without success. After it’s ejected, I can see the disc is burned and that the .iso file is there but no bluray reader can support it. Could anyone please help me?
Thanks in advance
Ana Trevisan
