Activity › Forums › Adobe Encore DVD › Blu-ray: Encore to BluStreak Tracer to replication – sectors error
  • Blu-ray: Encore to BluStreak Tracer to replication – sectors error
    Posted by Ethan Benninger on November 17, 2012 at 3:47 am
    Hello, I am trying to author a Blu-ray disc for replication. I began in Adobe Encore CS6 and exported out both a BDMV folder and an .iso
    In BluStreak Tracer, when I go to build the BDCMF folder for replication I get a pop-up which reads, “Output will be invalid because of errors. Ignore the errors and continue with output anyway?”
    When I review the errors I see 2:
    Length of segment 1 of transport stream file 00011.m2ts must be a multiple of 96 sectors.
    Length of segment 2 of transport stream file 00011.m2ts must be a multiple of 96 sectors.
    So far, I’ve read here on the forums that sometime sector size errors can crop up when authoring a DVD, and CSS/Macrovision has been enabled. However, there are no CSS/Macrovision settings for a Blu-ray within Encore.
    Any help would be great.
    Ethan
    Ethan Benninger
    Video Post-production
    People Productions
    Intelligently Integrated Media
    http://www.peopleproductions.com
    1737 15th Street, Suite 200
    Boulder CO 80302
    (303) 449-6086
    Daniel Ludwig replied 13 years, 10 months ago 2 Members · 1 Reply
  • Daniel Ludwig
    November 17, 2012 at 7:46 pm
    hey Ethan,
    this error might only accure, when encore output is not correct multiplexed.
    you might also look for the latest version of tracer CMF, please use the automatic update-function that´s been within the application.
    be awared to only use 1 (one) single video-asset within a single timeline at a time, encore is no editing-software.
    we´ve tested encore output with tracer cmf a lot without any problems – no eclipse error, neigther sony stream verification, but I need to tell you I haven´t tested CS6 output so far (have been CS4 and CS5 + 5.5.)
    if you are still running into trouble you might sent an email to larry or robin – to me it sounds like your data is corrupted.
    assets encoded prior authoring?
    cheers
    danny
