Activity Forums Apple Final Cut Pro Legacy Blu Ray- burn BD later in time
  • Chris Borjis
    November 2, 2009 at 5:29 pm
    I would just copy the BDMV and certificate folder and burn with Toast if you can’t
  • Arnie Schlissel
    November 2, 2009 at 9:27 pm
    Use Share to make a disk image, then use Toast or Disk Utility to burn that.
    Arnie
    Post production is not an afterthought!
    https://www.arniepix.com/
  • Daniel Dunn
    November 2, 2009 at 11:08 pm
    Do either of you know if the (limited) menu is included as part of the file?
    Daniel
    http://www.ddunnproductions.com
  • Albert Oconnor
    April 15, 2010 at 5:07 pm
    >>Daniel said, “…I’m using the new FCS. I want to burn a second Blu Ray disc a week after I made the first one. Do I have to go through the whole share process from Final Cut and create an entire new file, or can I use the already created file and just burn a new disc.Thanks…”
    I too want to know the answer to this question while working within FCP or Compressor, not a third party software solution as was suggested by the previous posters.
    I have searched the ‘net high and low for the answer to this question: FCP7 says you can burn a blu-ray disc or create a disc image but there are NO instructions how to take the disc image files and burn them to a blu-ray disc at a later date, so how is this done within the confines of FCP or Compressor?
    Bert
