Activity › Forums › VEGAS Pro › Blu ray 25gb fit 2 hours 10 minutes project
  • Blu ray 25gb fit 2 hours 10 minutes project
    Posted by Thayalan Paramasawam on December 28, 2013 at 3:59 pm
    Hi Sir,
    My project file is 2hours 10 minute,i need to fit into blu ray 25gb.
    Question 1
    Is there any culcalator for blu ray?So i can set the bit rate.
    Question 2
    What bitrate should i use to fit my media into blu ray?
    I use Mpeg 2 bluray 50 i to render my project.the out put is 23gb so i use dvda for authoring but the space in blu ray over then 25gb.
    Pls help me on this matter…..very urgent
    Thayalan Paramasawam replied 12 years, 9 months ago 2 Members · 6 Replies
  • Dave Haynie
    December 28, 2013 at 9:42 pm
    Any bitrare calculator can be used, just set the size to 25GB rather thsn 4.7, and work it otherwise as one would for DVD. Given typical AC-3 audio, this would work out to about 25Mb/s for the video. You’ll get a better quality video using AVC rather than MPEG-2.
    -Dave
  • Thayalan Paramasawam
    December 28, 2013 at 11:05 pm
    Thank you for reply sir,
    Is thete any free bitrate calculator for blu ray
  • Dave Haynie
    December 29, 2013 at 2:56 am
    Again,just about any bitrate calculator will work, as long as it alliws tge target medium or size to be selected. I use one called “video bitrate calculator” bincsoft for Android that can do this pretty easy. Not much more difficult to do “by hand” using a plain old four-function calculator.
    -Dave
    December 29, 2013 at 3:09 am
    hank you very much sir for your adivice……
    December 29, 2013 at 11:22 am
    Hi Sir,
    Sorry for asking same question.
    1)Can i use the marks dvd bitrate calculator for blu ray?
    2)On marks dvd calculator,i select user defined capacity,is it correct?
    3)in rendering using SONY AVC/MVC which template should i use?
    a)Blu ray 1920×1080 50i,10Mbps video stream
    b)Blu ray 1920×1080 50i,16Mbps video stream
    Pls help me on this matter.
    Thank you
    December 29, 2013 at 11:24 am
    Hi Sir,
    Thank you
