Activity Forums Adobe After Effects BLOW UP HDV to 2K by photoshop
  • BLOW UP HDV to 2K by photoshop
    Posted by Jopie on July 11, 2005 at 3:01 pm
    Hi ,
    Is it possible to blow up HDV resolution 1440X 1080 to 2K resolution by photoshop or after effects? E.g. frame by frame as a tiff or tga sequence.
    How does it happen at lab’s?
    Any tips trics or cheats???????
    grtz
    Jim -thanx for responding-
    Jopie replied 21 years, 1 month ago 2 Members · 2 Replies
  • Realethan
    July 12, 2005 at 4:18 am
    Sure.
    Create a 2K comp in AE. Import your HDV 1440×1080 footage to the library, and drop into your 2k comp.
    Enlarge your HDV footage to roughly 142%, and render as TGA or TIFF sequence using the render queue.
    This should work with progressive footage, if not, you’ll need to deinterlace prior to enlarging.
    But, any way you slice it, this will take mucho time and HD space.
  • Jopie
    July 12, 2005 at 8:04 pm
    thanks for the reply.
    Im gonna check it out… Will thequality still be OK?
    grtz,
    Jim
