Activity › Forums › Adobe After Effects › blood help
blood help
Posted by Cyprusx on June 24, 2007 at 7:06 amheay
Iv only had after effects for about a week, and i don’t know how to make a realistic blood effects. If someone could help me with that, it would be great. im cutting somthing with a knife so i need a fast blood effect. thanksMoviemaker2727 replied 19 years, 3 months ago 5 Members · 4 Replies -
Kuaishou
June 24, 2007 at 6:54 pmhi…u could try shooting it and then comping it in AE…if not theres a series of tutorials about blood splatters in creativecow podcast u can look at…or u can visit video copilot for more tutorials…cheers…merv
Mike Clasby
June 24, 2007 at 9:36 pmAndrew, aka The Master of Mayhem, has tuts and sells gory stuff galore on his site:
For some freebies (the free downloads) and more to buy, cheap, try this:
Blood
https://www.detonationfilms.com/UnitK.htmThere are more pages and freebies on the detonation site.
Zachary Nicholas
June 24, 2007 at 11:58 pmWhat kind of blood are you looking for if it’s burst’s probably go with Andrew Kramer or Denotation Films. But if your going for the look of a knife stabing in someone or a slice mark you could make a red solid and draw a mask around the place you want the blood and apply effect>Distort>Turbulant displace, and change the amount to around 30 the size about 15 and the complexity to 5 and you can adjust it from there. Know for the red solid layer change the transfer mode to classic color burn and it will have the effect of it blending with the shirt. if your working with the professional version you can track the knife and create a null object and put the track target to the null object and parent the red solid to the null object and it will move with the body. If you don’t know what parenting is it is the little coil looking thing by the transfer modes, and just click and drag it to the null object and that will parent it. If you don’t see the transfer modes or the parenting whip hit F4 to toggle the different option
Moviemaker2727
June 28, 2007 at 3:49 pmHey, if your that early in your ae usage you may not understand that most of the blood effects you see are included in plugins. The one i use is Action movie essentials from andrew kramer over at videocopilot.com also just a peice of advice watch most his tutorials even if you dont need those particular effects, i found it as a really great way to learn ae and most of the basics and youll find yourself having ideas on how to create your own effects.
