Activity Forums Adobe After Effects Expressions Blink slider to control the Y position of another layer.
  • Blink slider to control the Y position of another layer.
    Posted by Roberto Mata on January 22, 2015 at 1:17 pm
    Hello,
    I’m new to after effects an have some trouble solving this expression I need.
    I’m rigging the head of a 2D character. I have set a slider to control the blinks of its eyes.
    The slider has three pairs of blink associated with if/else.
    From 0 to 10: eyes closed.
    From 11 to 20: sibylline eyes.
    From 21 to 30: neutral eyes.
    Frpm 31 to 40: wide open eyes.
    I’ve used this kind of expression:
    a=thisComp.layer(“HEAD_CTRL”).effect(“BLINK”)(“Slider”);
    if((a>30)&&(a<=40)) 100 else 0
    NOW, I want the eyebrows to change their Y position with just one blink mode, the wide open eyes. So I wrote down the Y value for both positions and made an expression for Y position like this:
    if((a>30)&&(a<=40)) 524 else 528
    And it worked, but then I needed to parent the eyebrows to the HEAD_CTRL, and when I did OBVIOUSLY the eye brows comp went crazy. I figured out it was because I set some fixed values for Y that wouldn’t work if I changed the HEAD_CTRL position.
    So I need some variation of that expression for any position of the HEAD_CTRL.
    I want the eyebrows, to be in some Y position when the blink slide is set to “SURPRISE EYES” and Y position +4 with any other.
    Something like this, but in proper java language:
    if((a>30)&&(a<=40)) Y position else Y position+4
    Thanks.
    Roberto Mata replied 11 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    January 22, 2015 at 2:57 pm
    Try this:
    if((a>30)&&(a<=40)) value else value+4
    Dan
  • Roberto Mata
    January 22, 2015 at 3:18 pm
    Worked great!
    Thanks, Dan. And sorry for my novice question.
