Activity Forums Adobe After Effects blend an image as a closed frame and loop it
  • blend an image as a closed frame and loop it
    Posted by Michele Stocco on June 12, 2009 at 11:44 am
    hello to everyone,
    i have my comp done and i want to add an external frame to it.
    i want to use the external part of a film’s negative that i’ve scanned as the frame.
    so, i want this film’s negative to move around the comp in a circular way. this means i should distort the negative in the 4 corners so that it would move sticked to the 4 sides of my comp and it should go on loop.
    i thought to use an adjustement layer with 4 masks (one for each corner of the comp) and use an effect to distort the negative. and here there is my first problem, i can’t really use a distort effect that can blend the negative in a smooth way (i tried with the Bezier deformation as well and it doesn’t really work). i’m thinking to do a mask and link the negative to that as if it was his path, but i can’t really figure out how.
    then the second problem, how can i do a loop of this layout/frame? i can’t really use keyframing cause it’s a closed circle.
    any help/suggestion will be REALLY appreciated!
    Thanks in advance
    Michele Stocco
    Editor/Post-production technician
    Michele Stocco replied 17 years, 2 months ago 28,775 Members · 1 Reply
  • Michele Stocco
    June 22, 2009 at 12:50 pm
    ehmmm, i had a difficult time as well to understand what i wrote. sometimes i have this kind of off/on in my brain…
    anyway here there is one example: https://www.megaupload.com/?d=S4TZHBUC
    here i just used one piece of the film, and i repeated it with a loop expression one each side.
    what i want is that the external film frame would be just one piece, that turns around the corner (maybe blending the film frame layer) and that moves itself as a loop.
    for this reason i thought to do an adjustement layer with a mask for each corner and apply a blend effect to the adjustement layer. but i canpt really achive a good result.
    i hope now it would be clearer…
    any suggestion?
    Michele Stocco
