Activity › Forums › Apple Motion › Blast Match Move
  • Blast Match Move
    Posted by Angelo Sergio on February 1, 2009 at 12:19 pm
    Hello I’m new on using motion and FCS suite. It is magic!
    Actually I’m testing the motion tracking and it works very very nice! I have created a short movie analized it and created a path movment (Analyze Motion).
    Then I have add a Particle Emitters (sparkles>Magic Dust) with a behavior and in the Inspector I have dragged the Analyze Motion layer.
    The magic dust follo the path and it is anchored in the movie: the result is perfect!
    The problems are if I use the same steps but with a different Particle Emiters. I f I use Pyro>Big Blast I have a different result!
    In this case the blast don’t follow the movment but it is fixed on the screen. If I select the blast layer and I play the movie I see the blast fixed but the anchor point moving on the path…
    Why don’t is the Blast moving like its anchor point ?!?
    Can someone help me ?
    Thanks for your time!
    Angelo Sergio replied 17 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
