Activity › Forums › DaVinci Resolve › blank red footage
  • Peter Chamberlain
    March 26, 2014 at 10:39 am
    Hi, let’s start by understanding what your system configuration is, OS, GPUs, etc etc. Can u see other clip codecs? Is this a new or previously working system? And which resolve exact version.
  • Paulson Lang
    March 26, 2014 at 1:25 pm
    Hi Peter,
    I am using 2011 imac(2.7GHz intel core i5,16gb ram).I am getting this problem after updating to mavericks,and not facing any problem with 5d and arri raw.
  • Paulson Lang
    March 27, 2014 at 7:14 pm
    Hi peter,
    Is there a solution to my problem?
  • Margus Voll
    March 31, 2014 at 9:08 am
    whats is the gnu config ?
    do you see red material in redcine-x?
    Margus
    https://iconstudios.eu
    https://vimeo.com/iconstudioseu/videos
    DaVinci 10, OSX 10.8.5
    MacPro 5.1 2×2,93 24GB
    GUI 4000 / GPU GTX 780
    DL 4K
    Eizo Color
    Scope Box
    Full Ligthspace CMS
  • Nat Jencks
    April 2, 2014 at 5:32 am
    Hi Paulus, is this problem intermittent? I haven’t seem this in a while, but I used to see this once in a while, where all R3D footage would go black. Always was solved by a reboot. I assumed it was flakey behavior from my RedRocket card. I’ve talked to many others with rocket cards who have seen this in resolve, although I don’t know if its really result of the rocket or software, or something else. May or may not be related to your current problem of course.
    best-
    -Nat
  • Margus Voll
    October 13, 2015 at 6:42 pm
    Many people have just moved to other forums BM forum and LGG.
    Margus
    Resolve 11
    BMC 2,5k
  • Nikola Mrdalj
    October 23, 2015 at 4:50 pm
    Ive had the same problem, but fixed it by disabling red rocket in prefs
    Film & Adverts Colorist, Media+ Belgrade, Serbia
    https://www.imdb.com/name/nm3829270/?ref_=fn_al_nm_1
  • Eric Santiago
    October 23, 2015 at 7:11 pm
    If you update the OS then try re-installing the RED Workflow as well as latest RCX.
    I would do same with Resolve.
