Activity Forums VEGAS Pro Blank area being added to end of rendered file
  • Blank area being added to end of rendered file
    Posted by Jeff Powell on March 13, 2007 at 1:13 am
    Every time I render a file a very small blank is added to the end. For example…I pull in a Digital Juice jump back file. Mark the looped region from start to end of file. And render as a Mpeg looped region only. Then if I play the new file as a loop background the were a be a brief “stutter” where the blank is at the end. I have even pulled this new file back into vegas, set the looped are just short of the end before the blank area and rendered again and again it will add a blank area to this new file???? any ideas what I am missing?
    Jeff Powell replied 19 years, 6 months ago 2 Members · 2 Replies
  • Gary Kleiner
    March 13, 2007 at 3:47 am
    Make sure that Quantize To Frames is turned on and re-trim your event bounderies to make sure you are trying to render whole frames.
    Gary Kleiner
    Vegas Training and Tools.com
    Learn Vegas and DVD Architect
    http://www.VegasTrainingAndTools.com
  • Jeff Powell
    March 14, 2007 at 2:45 am
    Thank you for responding. It is turned on and full frames. The original loop I am using is 270 frames. The new mpeg is also 270 frames, but is frame 270 that is black instead of the last frame of the original loop?
