Activity Forums Apple Final Cut Pro blade speed FCPX repositioning
  • blade speed FCPX repositioning
    Posted by Kinga Kielczynska on August 22, 2019 at 8:31 pm
    Hi ALL,
    while working with speed ramping once I have put a blade marker in I can’t work out how to:
    1.remove it (apart from immediate undo, i.e. later on)
    2.move its position in relation to the src clip, i.e. I put the blade point in the wrong place, I want to move it without adjusting the retiming either side of the point
    3.join adjacent retimed segments… related to above, if I put in a new blade point in the correct position I can’t remove the wrong one (1) or see a way to join/merge the adjacent retiming segments
    thanxx for help!
    kinga
    Kinga Kielczynska replied 6 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
