Activity Forums Adobe After Effects blacks losing density upon render out
  • blacks losing density upon render out
    Posted by Aidan Wood on February 16, 2010 at 2:19 pm
    Hi all, and thanks for taking the time to read this.
    I’m color correcting some footage and using some feathered vignettes and other simple techniques. Nothing too fancy, but I’ve spent a long time getting the footage to look just the way I want it!
    So my RAM preview looks great.
    Problem is that when I render out and watch my footage back in quick time, the blacks look washed out and less dense, which really ruins my effect. It makes me feel like I put all that time in for nothing.
    Anyway, I’ve looked on the site for a solution, and tinkered with my export settings here and there, but not much is helping.
    I’d really appreciate any suggestions / a nudge in the right direction, if someone would post a link of two, I’m happy to do the reading and legwork : )
    Hunter Hempen replied 15 years, 10 months ago 3 Members · 3 Replies
  • John Cuevas
    February 16, 2010 at 7:27 pm
    Not sure about watching it in quicktime, but this issues happens to me when I go from AE to Avid and don’t take into consideration RGB to 601color levels.
    Easy fix for this—add adjust layer over everything-set the black imput to 16(if it’s still 0 to 255) and the white to 235. That will correct the difference and keep it broadcast legal.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Hunter Hempen
    November 6, 2010 at 11:14 pm
    I have a problem similar to this, so I’m going to go ahead with what you suggested. And I assume you’re adjusting the input blacks through Levels?
    I’ll respond back with the results,
    Thanks again!
    -Hunter
  • Hunter Hempen
    November 7, 2010 at 3:56 am
    Ah!
    Thanks once more!
    Turned out great.
