Activity › Forums › Media 100 › Blacks arn’t blacks
  • Blacks arn’t blacks
    Posted by Elliott Dunwody on December 10, 2008 at 4:30 pm
    We are working on a project and some of it has been edited in FCP. The issue is that the blacks in M100 aren’t black. They are a milky dark grey and there is a noticeable difference.
    What’s up with that?
    Elliott
    Bright Blue Sky Productions
    4811 Rivoli Dr
    Macon, GA 31210
    http://www.brightbluesky.com
    Elliott Dunwody replied 17 years, 9 months ago 3 Members · 4 Replies
  • Chris Clephane
    December 10, 2008 at 8:01 pm
    Simple answer: Black in question was most likely generated in a 16-235 colorspace with a 7.5 % setup vs. a 0-255 colorspace with black being a value of 0.
    Yes, its highly annoying.
    I edit video. I post sometimes.
    I fix things. I eat marshmallows.
    I play drums. I drink scotch.
    I like TV.
    Done typing now.
  • Elliott Dunwody
    December 10, 2008 at 9:25 pm
    Is there a easy fix after the fact?
    Elliott
    4811 Rivoli Dr
    Macon, GA 31210
  • Wickham Strub
    December 11, 2008 at 2:02 am
    Hey Elliott,
    How have you been?
    The best you can do to solve a “dueling color spaces” problem like this is to try to match up the codecs. I’m guessing that you cannot re-capture the FCP media, so try to re-acquire the M100 media to the same codec as the FCP stuff.
    As always, do a couple of short tests before diving all the way in.
    ~Wick
  • Elliott Dunwody
    December 15, 2008 at 8:15 pm
    Thanks Wick, will give it a try.
    Elliott
    4811 Rivoli Dr
    Macon, GA 31210
