Activity › Forums › Blackmagic Design › Blackmagic Ultrastudio 3d – Video Output to Eizo CG27W Coloredge
  • Blackmagic Ultrastudio 3d – Video Output to Eizo CG27W Coloredge
    Posted by Crescenzo Mazza on October 25, 2012 at 9:12 pm
    Just arrived a couple of EIZO Coloredge CG27W, to complete the following editing setup:
    – Imac 27 late 2011;
    – Apple Thunderbolt Display;
    – Blackmagic Ultrastudio 3D;
    Eizo has DVI-D input, mini display port and display port.
    What is the solution to playback 1080 material on Eizo starting from Ultrastudio 3d?
    – HDMI to DVI-D cable: no signal;
    – Blackmagic HDLINK PRO?
    – AJA HDP2?
    – GEFEN SDI to DVI adapter?
    – KRAMER VP-471
    The Eizo works perfectly attached via thunderbolt mini display port but I need to use it via broadcast card.
    Thanks in advance for help.
    Crescenzo
    Luca Salmy replied 13 years, 10 months ago 3 Members · 2 Replies
  • Alex Gerulaitis
    October 25, 2012 at 10:06 pm
    [Crescenzo Mazza] “What is the solution to playback 1080 material on Eizo starting from Ultrastudio 3d?
    – HDMI to DVI-D cable: no signal;”
    I suspect (but could be dead wrong) that UltraStudio outputs 1080p29.97 or 1080i59.94 that Eizo can’t sync to over DVI. I’d try HDMI-to-DP, since DP spec supports a wider range of frame rates than DVI. If that does not work, I would try one of the converters you mentioned.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
  • Luca Salmy
    November 26, 2012 at 12:34 am
    I’ve now the same your problem!!!
    I’ve to playback 1080 material on Eizo starting from Ultrastudio 3d!
    How have you resolved the problem??
    THANKS very much!!
