Activity Forums Apple Final Cut Pro Legacy Blackmagic Multibridge Extreme to a DVI monitor
  • Blackmagic Multibridge Extreme to a DVI monitor
    Posted by Per Ottesen on June 27, 2006 at 8:17 pm
    I’m having problem to get the DVI signal out of the BlackMagic Multibridge Extreme to an Apple Cinema Display 23″.
    We are using FCP on a PowerMac Quadra with 4 GB RAM, and the setup in FCP for Sequence/Capture Presets is:
    Walter Biscardi replied 20 years, 2 months ago 2 Members · 3 Replies
  • Walter Biscardi
    June 27, 2006 at 9:31 pm
    Have you checked in the BlackMagic forum?
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Per Ottesen
    June 28, 2006 at 1:38 pm
    Thanks, don’t know why I wasn’t thinking of that in the first place.
    There was a thread that solved the problem (the video playback was set to the monitor resolution, where it should have been set to timelines resolution).
  • Walter Biscardi
    June 28, 2006 at 1:44 pm
    [Per Ottesen]
    Thanks, don’t know why I wasn’t thinking of that in the first place.”
    while this is certainly a great forum to find out all things FCP, with the manufacturers supporting the Cow with their own forums, you can often find hardware specific answers quicker in the AJA, BlackMagic and Aurora forums directly.
    Glad you got the answer you needed quickly.
