Activity › Forums › Blackmagic Design › BlackMagic MJPEG codec without declink hardware
  • BlackMagic MJPEG codec without declink hardware
    Posted by Iorecc on February 25, 2007 at 1:49 pm
    helos.
    i have a video file that was encoded with blackmagics mjpeg codec. if i playback that file on a windows machine without any decklink hardware or codec installed it works, but is quite jerky.
    therefore i installed the free blackmagic-codec 4.9 in the hope that playback would improve. but it doesn’t. directshow still seems to use its own built-in mjpg-decoder (which i can see using graphedit). am i missing something? shouldn’t directshow use the blackmagic-decoder when available and plaback the file smoothly even on machines without decklink hardware installed?
    thanks in advance for clarification.
    Iorecc replied 19 years, 7 months ago 2 Members · 2 Replies
  • Igor Babic
    February 25, 2007 at 9:44 pm
    Install latest drivers even if you dont have DL hardware in your machine.
  • Iorecc
    February 26, 2007 at 1:25 pm
    horray. that does the trick. i didn’t find that being mentioned anywhere. thanks again.
