Activity Forums Adobe After Effects Blackmagic export
  • Blackmagic export
    Posted by Alex Dinnin on January 5, 2011 at 6:14 pm
    Hi There,
    I’m rendering out of After Effects to import into Premiere to layoff to tape..
    What Native renderer should I use from After Effects… So premiere doesn’t need to render before it exports to tape..
    I thought it was either Blackmagic 10bit or Uncompressed YUV..
    But all of these need to render first ???
    Any help would be greatly appreciated
    Alex
    Alex Dinnin replied 15 years, 8 months ago 2 Members · 3 Replies
  • David Johnson
    January 5, 2011 at 11:03 pm
    Just to add a little detail to Dave’s suggestion to use “the codec of your other footage in Premiere”, it’s best to make sure everything else is the same too … frame rate, frame size, PAR, audio codec, etc.
  • Alex Dinnin
    January 5, 2011 at 11:14 pm
    I dont actually have any footage to match it with.
    But I kinda see where you are coming from. I’ll check when I get into work in the morning.
    Alx
  • Alex Dinnin
    January 6, 2011 at 10:01 am
    I solved the problem..
    I was being an idiot.. it was YUV 8 bit..
    I was working in 1050 x 576… forgot to squash it to 720 x 576 at render..
    doh !!!
    Thanks for all your help…
    Alex
