Activity › Forums › Apple Final Cut Pro Legacy › Blackmagic, DVCPRO HD, HDV & FCP
  • Blackmagic, DVCPRO HD, HDV & FCP
    Posted by Stuart Dworeck on October 27, 2008 at 6:56 pm
    I am editing a project in FCP for eventual film release. Most of our original footage is DVCPRO HD 1080p24 shot on the Panasonic AJ HDX900 camera. Some of our additional footage is shot on the Canon VIXIA HV30 camera set to HDV PF24. I have two questions about loading in footage for this project.
    1. Can we use our Decklink Extreme HD card to capture the Panasonic DVC PRO HD 1080p24 footage into FCP via SDI? And how do we do that? We want to stay in the DVCPRO HD codec. We use a Panasonic 1400 deck to playback the tapes for capture. I’ve been told to put the deck into it’s 23/24 playback mode (as opposed to the standard 59/60 mode) and to use SDI to capture the footage at 23.98. What Blackmagic Capture/Input setting should I use in FCP to do this so we lose the pulldown frames the Panasonic HDX900 adds when it records the 1080p24 to the camera tape? The first batch of footage we loaded into FCP was done using the 1400 deck via Firewire and captured at 1080i60 and then converted using the Cinema Tools reverse telecine process. I’d like to skip that time and disk space consuming step and load into FCP directly at 1080p24 (or rather 23.98). Can the Blackmagic Extreme card do that?
    2. Can I load the footage being shot with the Canon HD camera (HDV pf 24) into FCP via an HDMI cable through the Extreme card? What Blackmagic Capture/Input setting would be best to use if this material will be intercut with the DVCPRO HD 1080p24 footage?
    Chris Borjis replied 17 years, 11 months ago 2 Members · 1 Reply
  • Chris Borjis
    October 27, 2008 at 10:23 pm
    [Stuart Dworeck] “What Blackmagic Capture/Input setting would be best to use if this material will be intercut with the DVCPRO HD 1080p24 footage?”
    DVCPRO HD 1080p24.
    if you have 1080 24p and you want it digitized as DVCPRO-HD
    just find the easy setup it matches.
