Activity Forums Blackmagic Design Blackmagic DV capture data rate / file size
  • Blackmagic DV capture data rate / file size
    Posted by Peterson on September 19, 2005 at 4:43 pm
    Hi – I am using my newly acquired Decklink Extreme to capture BetaSP video into FCP 5 and using the Blackmagic DV-NTSC capture preset. However, the file sizes and data rate are running considerably larger than I’d expected: about 300mb per minute of video and a data rate of 42.50 mb/s. DV is usually somewhat smaller – 200mb per minute of video and a data rate of 25mb/s.
    As I am looking at a lot of capture, this will add up very soon. Am I doing something wrong?
    Thanks –
    pete
    Peterson replied 21 years ago 2 Members · 2 Replies
  • Kristian Lam
    September 20, 2005 at 12:19 am
    Please check that you’re not capturing more audio channels than required. You can do this in the Log and Capture window under the Clip Settings tab.
    regards
    Kristian
    Blackmagic Design
  • Peterson
    September 20, 2005 at 3:03 pm
    Oops, my mistake: that seems to have been the problem. Thanks for the tip & your time –
    pete
