Activity Forums Blackmagic Design Blackmagic Design DeckLink for Macintosh v5.0.1 software
  • Blackmagic Design DeckLink for Macintosh v5.0.1 software
    Posted by Matt Dowling on August 30, 2005 at 8:06 am
    Hi Everyone,
    We have released the 5.0.1 update for Mac and it can be downloaded from
    https://www.blackmagic-design.com/downloads/software/DeckLink_Macintosh_5.0.1.zip
    Due to popular demand, the Blackmagic codecs are now back in the installer. We also did a few tweaks so when you render from After Effects it will use the BMD compressor and decompressor – which will match the Apple codecs gamma, no more gamma shifts!
    Please keep us posted on the results.
    Cheers,
    Regards,
    Matt
    Blackmagic Design
    Felix Mack replied 21 years ago 16 Members · 41 Replies
  • 41 Replies
  • Tor Anders
    August 30, 2005 at 9:58 am
    Oops, major problems. My G5/FC 5/Tiger/Decklink HD became unstable and would not play back a DVCPRO 720p60 project I
  • Mark
    August 30, 2005 at 3:39 pm
    Geez…. installed update and all hell is breaking loose in FCP. No video and FCP will not stay open for 2 minutes before crashing. I’m just gonna pray I can get back…..
  • George Kalishkin
    August 30, 2005 at 4:15 pm
    i got problem – FCP hangs on load at “Loanding audio filters: AUNetSend”
    multiple restarts and cache cleaning helps for me.
  • Roddy Jamieson
    August 30, 2005 at 4:26 pm
    My FCP is opening and forgetting my layout settings. I just saved the project and quit. Then it tells me that it “unexpectedly quit!” I think I’ll revert to version 5, just means I’ll loose all my preferences……aaaaargh.
    Roddy Jamieson
  • Roddy Jamieson
    August 30, 2005 at 4:30 pm
    If it’s any help to Blackmagic here’s what the first few lines of my crash report say:
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x0000000c
    Thread 0 Crashed:
    Roddy Jamieson
  • Peter Mackay
    August 30, 2005 at 4:50 pm
    OK so I installed the new drivers, I’m not having the same crashing problems as the other users in this post, but I am having a problem where, when I stop the timeline the picture in the NTSC monitor gets brighter (substantially) this is making color correction very difficult. some of my shots are short and have to corrected in the stopped position. But the monitor is not showing me what i am really getting. HELP!!!!!!
  • Mark
    August 30, 2005 at 6:25 pm
    For what it is worth. Working in 8bit unc FCP seems ok, but as soon as I try to do a 10bit Unc easy set up CRASH…
  • Mark
    August 30, 2005 at 6:34 pm
    ….and another weirdness…. when I try to “remove Blackmagic” and then install 5.0 I get constant message that “decklink file has damaged content…” I have downloaded it several times with no success.
  • Brandon Turner
    August 30, 2005 at 8:09 pm
    think i’m gonna wait this one out 🙁
  • Sean Oneil
    August 30, 2005 at 8:23 pm
    Why are these botched drivers still on the website after 12 hours? 5.0 should go back up immediately. I tried 5.01 for about two minutes and had a serious problem.
    I did a simple insert edit to tape from a 10-bit sequence. It inserted a green flash at the in point and the out point. I immediately came here, saw these were screwed up, reverted to 5.0, and then tried it again. It worked fine.
Page 1 of 5
