Activity › Forums › Blackmagic Design › Blackmagic decklink won’t install in a Dell PC?
  • Blackmagic decklink won’t install in a Dell PC?
    Posted by Carly Smith on May 30, 2011 at 11:49 am
    Has anyone else had trouble installing a Blackmagic decklink HD card in a Dell running Win 7 64 bit?
    Spent quite a bit of time with the folks there trying to get it to work (apparently Dell doesn’t like the drivers) but they did not have a suggestion as to what make/model would work?
    Card is a Decklink HDPro SD that will connect to an analog to SDI Mini Converter (also made by Blackmagic) so we can use it with our Vaddio board that has 6 inputs.
    Yes we are still using analog boards at this time – can’t afford to upgrade to HD yet.
    All suggestions appreciated…
    TIA
    C
    Alex Gerulaitis replied 15 years, 4 months ago 3 Members · 3 Replies
  • Paul Jay
    May 30, 2011 at 12:41 pm
    Works in a MacPro 100 out of 100.
  • Carly Smith
    May 30, 2011 at 1:34 pm
    thanks but we won’t be converting to Macs anytime soon. That is not an option for us.
  • Alex Gerulaitis
    June 2, 2011 at 10:58 pm
    Carly,
    Which Dell is it? What are the error messages if any?
    Have you tried installing the card in a non-Dell system to rule out a possibility of a defective card?
    Alex (DV411)
