Activity Forums Blackmagic Design Blackmagic Decklink HD Extreme – 24fps sequence Playback on PAL TV
  • Blackmagic Decklink HD Extreme – 24fps sequence Playback on PAL TV
    Posted by Crescenzo on September 29, 2006 at 3:31 pm
    Hi, I need to play correctly sequences edited coming from 35mm material filmed at 24fps.
    These are the the steps I’ve done but I’ve a problem with playback on TV Monitor.
    1 – I import Telecine logs from Cinema Tools creating a Database from a .flx file
    2 – I Capture the automatic Batch Capture from Beta SP recorded at 25fps. (after a check every timecode and keycode burned on film correspond to timecode and keycode in Cinema Tools and Final Cut)
    3 – Then I conform the clips with Cinema Tools from 25fps to 24fps.
    4 – I sync the video subclips with the audio clips.
    5 – I play these clips on the timeline with 24 fps setting on Digital Cinema Desktop with excellent results.
    6 – When I set the video playback out to my Sony Monitor Pal I have this issue: the video is flickering using 24@25 pulldown or there’s a soft freeze every 24 frames using 24@25 repeat.
    Many thanks for help !
    Please help me to find a way to have a smooth playback ! Thanks.
    G5 Dual 2.3 Dual Core 2,5 GB RAM – Mac OS X (10.4.7) – Blackmagic Decklink HD Extreme
    Anders Haavie replied 19 years, 8 months ago 2 Members · 1 Reply
  • Anders Haavie
    January 19, 2007 at 6:32 pm
    You have to use the firewire out. Decklink does not support this feature. If you connect a dv player via firewire, and connect your monitor to the dv player everything works. When will Decklink support this ?? No idea.. very annoying
    Anders
