Activity › Forums › Blackmagic Design › Blackmagic Decklink Extreme – why no 1080 25P
  • Blackmagic Decklink Extreme – why no 1080 25P
    Posted by Justin Tan on March 3, 2006 at 12:58 am
    Just curious, I have a job that was recorded at 25P but the only setting I have is 1080i 25hz…
    theoretically it should be fine right? but it does introduce fields when it playsout…
    Justin Tan replied 20 years, 7 months ago 2 Members · 6 Replies
  • Kristian Lam
    March 3, 2006 at 4:37 am
    Hi Justin,
    It sounds like you’re doing a down conversion as you’re using a DeckLink Extreme card. This means that your 1080/25PsF HD will be coming out as PAL which will be interlaced.
    regards
    Kristian Lam
    Blackmagic Design
  • Justin Tan
    March 3, 2006 at 7:36 am
    sorry, I have a multibridge extreme… trying to bring in 1080i 25PSF image into FCP
  • Kristian Lam
    March 3, 2006 at 9:56 pm
    Use the 1080i50 Easy Setup, then go into Sequence Settings and set field order to “None”.
    regards
    Kristian Lam
    Blackmagic Design
  • Justin Tan
    March 6, 2006 at 12:46 am
    so does that mean when we playout it will playout as frames instead of fields as well?
    thx Kristian…
  • Kristian Lam
    March 6, 2006 at 3:20 am
    [Justin] “so does that mean when we playout it will playout as frames instead of fields as well?”
    That’s correct. By turning off the field dominance option in Final Cut Pro, you get frames instead of fields.
    regards
    Kristian Lam
    Blackmagic Design
  • Justin Tan
    March 6, 2006 at 10:20 am
    thx again Kristian, I have been having an issue where the second field of every frame seems to lift black values, this might have inadvertantly Solved that problem…
