Activity Forums Blackmagic Design Blackmagic Cinema Camera SSD
  • Juan Salvo
    April 29, 2012 at 7:12 pm
    These don’t work with the hyperdeck. Don’t expect them to work with the Camera. Certainly wouldn’t be useable for RAW recording.
    online editor | colorist | VFX | BD author
    https://JuanSalvo.com
  • Glenn Sakatch
    May 1, 2012 at 2:02 pm
    They might plug into that slot, but the data rate on an SSD is higher than the spinning disc version of a Hard Drive. That data rate is what you need to get those recordings to work.
    Even if it did work,one bump on the camera, you could lose your entire hard drive.
    That wouldn’t sit well with too many clients.
    Glenn
