Activity › Forums › Blackmagic Design › Blackmagic 10bit RGB 444 codec cross compatibility concerns…
  • Blackmagic 10bit RGB 444 codec cross compatibility concerns…
    Posted by Justin Tan on April 12, 2006 at 10:42 pm
    Hi all,
    I’ve just notice something which I have not seen posted on these forums as yet and while it may be considered a small issue, I believe it is a problem…
    What happens is when a PC reads a QT with the blackmagic 10bit RBG 444 codec the very top line of pixels is black.
    The good thing (so far from what I have seen) is files rendered out of the PC with the same codec (while missing the top line on the PC, looks fine on a MAC).
    The problem is that, if you use a program to read a QT with the same codec and then output, it is output with that top line blacked – on BOTH PC and MAC…
    hope I make sense, Kristian let me know if you need to send you a JPG…
    Sirayz replied 20 years, 2 months ago 3 Members · 3 Replies
  • Kristian Lam
    April 13, 2006 at 4:03 am
    Hi Justin,
    Yes, the JPEGs will help. How many pixels are we talking about here?
    regards
    Kristian Lam
    Blackmagic Design
  • Justin Tan
    April 14, 2006 at 1:56 pm
    It’s the very top line – so 1 pixel.
    something to note – is that the PC DOES NOT have a BM card in it – but then again, neither does the other MAC where the codec was fine…
    I’ll send u jpg when I get to work Kristian…
  • Sirayz
    July 20, 2006 at 12:27 pm
    I have been experiencing the same problems with more than one system, with different hardware/software configurations. Did anyone find a resolution for this?
    SR
