Activity Forums Adobe After Effects Black & White effect?
  • Black & White effect?
    Posted by Matt Jones on May 4, 2010 at 3:35 pm
    Hey Guys,
    Total noob question, I know, but I can’t for the life of me seem to figure out how to make a clip black and white. I can’t find a simple saturation effect, nothing…any help would be appreciated, thanks!
    I’m using CS3, if that makes any difference.
    – MJ
    Darby Edelen replied 16 years, 4 months ago 3 Members · 2 Replies
  • Todd Kopriva
    May 4, 2010 at 4:39 pm
    There’s a Black & White effect in After Effects CS5.
    For previous versions, and for less control, there are other effects in the Color Correction effects category. There is a Hue/Saturation effect in that category.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Darby Edelen
    May 10, 2010 at 8:31 pm
    In addition to the other good responses, you can use the Color Correction > Channel Mixer effect set to ‘Monochrome’ to change the influence that the R, G and B channels have on your B&W image.
    The Red-Red, Red-Green and Red-Blue can, respectively, be used to adjust the influence that your Red, Green and Blue channels have on the final monochromatic image. Something close to 25 – 60 – 15 would be similar to the Tint effect (approx. numbers).
    -Darby
    Darby Edelen
