Black magic Multibridge or Kona or Matrox MXO?
I only need to monitor from Final Cut Pro’s Timeline; no input or output needed.
The monitor has (2) SDI SD/HD inputs
S-video input
YPrPb/RGB input (with input for VD-vertical sensing signal)It would be ideal to go to SDI since the monitor senses HD/SD signal and adjusts automatically.
I like the Multibridge because it is external and would seem to work with my G5 and MacBook Pro.
Any input on Multibridge vs Kona vs Matros MXO?
G-5, 2.5 GHz, 8 GB Ram Mac OS X (10.4.8) Nvidia Geforce 6800, 30″ Cinema Display
Panasonic monitor:
https://catalog2.panasonic.com/webapp/wcs/stores/servlet/ModelDetail?storeId=11201&catalogId=13051&itemId=97137&catGroupId=14625&surfModel=BT-LH2600W&displayTab=RG-5, 2.5 GHz, 8 GB Ram Mac OS X (10.4.8) Nvidia Geforce 6800, 30″ Cinema Display
